I may have mentioned before that the fuel tank had a lot of rust in it. I filled it with a vinegar solution and a handfulf of small square nuts. Rocked it around for several minutes then left it sit for a while........ actually I left it for over a week during the Christmas holidays
. On emptying the vinegar it looked worse than before I had added the solution. Well, after watching several youtube videos I went for it. I mixed up 5 gallons of distilled water and a cup of Arm&Hammer laundry booster soap which is bicarbonate of soda, and when dc current via an anode and a cathode are connected it activates a current, drawing rust to the anode.
- IMG_2698.JPG (258.22 KiB) Viewed 38338 times
After about 30 minutes I withdrew the anode and this was what came out. It took several 30 minute cycles before the anode came out with just a small amount of rust. I used the pressure washer to flush it out and dry it before adding a gallon of 2 stroke gas for a final rinse. It's finally nice and clean.
- IMG_2716.JPG (212.57 KiB) Viewed 38338 times
