by Lotus54 » Wed Feb 01, 2023 12:24 pm
I fit piston/rings/cylinder.
I fit an aftermarket ignition/charging, so have to set timing. They give it in degrees or mm on the flywheel. Of course, the flywheel is a different size. I didn’t think to measure the rod length when apart- with that it is seconds with an online calculator.
I could fit my cam timing wheel- but that would sure take longer than a few seconds.
I suspect this engine is not very touchy on timing, it is fairly modest in output. But it would be nice to know and a lot easier to setup on the bench.
Guess it is time to fit the wheel. (I did transfer from the other flywheel by eye, and likely that is close enough).
- 36410849-7465-47E7-96D5-EFB181DB3BA9.jpeg (364.08 KiB) Viewed 85290 times
