by Lotus54 » Sun Dec 25, 2022 1:11 pm
I have taken the 175 engine apart. The countershaft sprocket was a bugger. I did finally get it off, the woodruff key was sheared. I do not know if when pulling it, or it already had sheared. The shaft is tapered also.
I am sourcing bearings etc. The gearbox oil had water in it- and I didn’t trust the bearings without inspecting. Some where not great, so I will just replace them all.
- A0C73454-F972-46FF-AF68-7667723F133C.jpeg (409.01 KiB) Viewed 41477 times
- A2B059DD-E8DD-4CA7-8EA0-DCC3D26A390D.jpeg (408.5 KiB) Viewed 41477 times
- 48C88940-A82F-4150-9B71-F8A98A215CE8.jpeg (454.99 KiB) Viewed 41477 times
