by Lotus54 » Sun Nov 13, 2022 5:59 pm
Yes, it is a sickness. (John will understand).
It started running poorly, and I was very suspect of the old crank seals. Since I was part way there anyway- I checked ‘dry’ side, then ‘wet’ side. I didn’t like either. And the exhaust port had a lot of carbon- so I pulled the head. Piston/head looked way too clean- decided to just pull cylinder and make sure how things look.
The cylinder studs need to come off to pull cylinder while in frame. First one came right out- second was stubborn and my stud puller taper was a little messed up. So start to setup lathe to clean up the taper- well the gibs were off and had to take things apart, clean and adjust (due anyway). It is a tiny lathe and needs all the help it can get.
Cleaned up taper and and heated stud- then it came out (an hour later of course).
Vaporhoned cylinder- looks pretty good, piston/rings looks like new. I think maybe some moisture was in it when it sat though.
I’m in the process of cleaning everything, replace crank seals etc.
Oh yeah, the carb needle is toast too. Haha (All good, I wanted to see condition anyway)
- A49A616C-DB06-4C18-8CC2-793763FB9EB1.jpeg (414.02 KiB) Viewed 43964 times
