Postby Lotus54 » Sat Sep 25, 2021 10:17 am
First start!
Fired right up and sounds great.
I’m busy a few days, but will attack major fitment issues with Busso pipes after that. I just had to hear it run.
Sasche ignition went right on with no issues and works very well.
https://youtu.be/_JlU-AGFDQY
Postby John H » Sat Sep 25, 2021 8:35 pm
Sounds awesome. Always a good feeling to hear them come alive after a major rebuild. Congratulations
Postby Lotus54 » Mon Sep 27, 2021 8:18 pm
I took it off the lift so I could run it more (without asphyxiating myself)
https://youtu.be/5BMz4kj_wLc
Postby Lotus54 » Wed Sep 29, 2021 7:30 pm
I finished fitting air filter housing and air filter- plus new battery.
Put on the spare side covers and finished up the crankcase breather/separator setup - just need one 1/2” hose.
I have the spare tank ready to fit the petcocks in and will use until I paint the tank/side panels.
I will get it where I can run it again with my test fuel bottle- hooking up the old Carb Stix and finish the carb sync.
Postby Lotus54 » Fri Oct 01, 2021 7:24 pm
I took the 750 sei out for the first ride!
Sure great to ride it- since it did not run when I got it.
Every nut/bolt/clip/part I took off, replaced or cleaned up and put all back together.
I have the spare fuel tank /side covers on (have not painted the original ones yet) and a couple other little things to do. But fired right up, runs great!
Postby John H » Fri Oct 01, 2021 8:39 pm
Has to be a geat feeling after so much time bringing the beast back to it's glory. Can't wait to see the finished product.
Postby Lotus54 » Sat Oct 02, 2021 8:00 pm
Longer ride today. About 75 miles so far.
Postby John H » Sun Oct 03, 2021 6:37 am
That's a real beauty. Congratulations on a project well done.
Postby Lotus54 » Sat Oct 09, 2021 6:02 pm
I got the new pipes.
they fit and look great!
John fixed up my rotors and cleaned up the one rust spot. Thanks so much!
Postby Lotus54 » Sun Oct 10, 2021 2:18 pm
Just a bit of a ride on the new Moto Storichei pipes.
I may have taken it to 5k rpm once, but really just cruising along. I think around 160 miles on the engine now.
https://youtu.be/lySoHSD-LXY
