More surprises after removing the main bearings. On the drive side case of motor #1 the bearing retainer
bore was oblong fore and aft as you can see from the dimensions in the first photo. On motor #2 it's just the opposite with the bore being oblong up and down. See the second photo.
I can only imagine this has something to do with the configuration of the engines.
The fix will be to bore and sleeve the cases to fit the new bearings.
- IMG_3666.JPG (203.9 KiB) Viewed 34023 times
- IMG_3664.JPG (260.65 KiB) Viewed 34023 times
