Postby John H » Fri Jul 31, 2020 9:05 pm
Haven't worked on the Double for a few days but still gathering parts. The grandsons are here for ten days so will be having lots of fun. My friend Alp is close to finishing his nitro burning Vinnie and plans on being at Bonneville next week with it.
His work is stunning and his bikes go as fast as they look. He's looking to be the first 1000cc vintage class fuel bike to go 200+ mph.
Postby ATinkerer » Fri Jul 31, 2020 9:11 pm
Mechanical sculpture. Beautiful, and purposeful.
Postby John H » Wed Sep 16, 2020 10:54 am
Work is progressing on the old drag bike. The drive line is complete except for the double sprocket from the rear engine to the clutch. I need to heat up the larger gear before it can be pressed on the hub of the engine sprocket.
Postby ClineDesign » Wed Sep 16, 2020 1:09 pm
Test of image upload... this is just a test.
Postby John H » Wed Sep 16, 2020 4:11 pm
x
Postby ClineDesign » Wed Sep 16, 2020 6:38 pm
Are you uploading photos from your computer or a image storage site?
Postby John H » Wed Sep 16, 2020 7:59 pm
x
Postby ClineDesign » Thu Sep 17, 2020 12:29 pm
I think it's more of a minor defugalty of the PHPBB forum software.
Postby John H » Sat Sep 26, 2020 7:52 pm
Thanks to Jay the photo issue has been resolved.
The drive line special sprocket is finished. It took extra heat and pressure to get both sprockets lined up perfectly.
IMG_3078 copy.JPG (214.93 KiB) Viewed 26145 times
The next step will be adding a 1-1/2" socket to the crankshaft for a remote starter. It will be the same starter I built for the Vincent land speed bike.
IMG_3079 copy.JPG (219.14 KiB) Viewed 26145 times
Postby John H » Thu Oct 01, 2020 8:44 pm
Copper head gaskets for the Routt 800cc cylinders are unobtanium. They were made to bolt up to mid 60s 9 bolt heads so I made a fixture using the damaged cylinder and a piece of formica covered wood to hold the gasket in place while opening up the bore.
The copper gaskets are annealed and very soft so not that easy to cut.
IMG_3047 copy.JPG (189.89 KiB) Viewed 26110 times
IMG_3051 copy.JPG (199.54 KiB) Viewed 26110 times
Users browsing this forum: Google [Bot] and 3 guests
