All holes in the frame have been cleaned of powder coating. Bearing races installed in the steering head as well as bearings fitted. I don't think the frame was made for this Ceriani fork set as the upper race that threads onto the stem ran out of threads before the proper drag on the bearings were met. So the stem was dropped .035" and a shim added. The locking crown nut was bottoming on the stem before it locked the tree against the upper bearing race. So another shim had to be made to correct this.. I know it all sound a bit anal but right is right, wrong is wrong.
The steering damper knob and parts are missing and were never very effective. If I had any intentions of ever racing this bike it would get a hydraulic steering damper immediately. It would look nice with the damper knob there wouldn't it.
I scored another early style Hilborn 150-0 fuel pump that is in great shape so will replace the old corroded unit.
- IMG_2335.JPG (219.73 KiB) Viewed 40064 times
