62 Triumph Bonneville
Re: 62 Triumph Bonneville
Postby Dragonknee » Mon Nov 19, 2018 5:59 pm
Its a beautiful bike, you are a master of making bikes come to life...
Postby John H » Mon Nov 26, 2018 10:50 pm
Progress has been slow lately but the Bonnie is a roller now. I'm still trouble shooting a wiring problem
(6 volt/positive ground). This was the last year for the 6v alternator/magneto setup. I'm waiting for a new rectifier and battery, then more testing.
Postby John H » Mon Dec 10, 2018 12:43 pm
Wow! with 10,000 views on the build, I'm shocked. Guess I'd better get back to work on the Bonnie. I've actually made some progress but nothing noticeable. Hopefully this week will be productive so I can wrap up the project.
Postby Dragonknee » Tue Dec 11, 2018 7:46 am
People await the finish... and then the next project. Well done John.
Postby John H » Wed Jan 02, 2019 8:12 am
Happy New Year!
What are your new year's resolutions?? I want to finish more projects.
We're on the home stretch with the Bonnie and should be ready to test it out next week. The first time I switched the headlamp on, the ammmeter needle showed a discharge but when the light was switched off the needle did not return until
I tapped the headlamp bucket. So a new gauge has been ordered.
I'm still looking for the correct 5/16 id x 9/16 od clear fuel line which is an odd size for a motorcycle but common in beer making accessories. The difference is beer tubing is not compatible with gasoline.
Postby ClineDesign » Wed Jan 02, 2019 6:18 pm
Postby John H » Sun Jan 06, 2019 6:22 pm
I found one at Motion Pro that will pass. https://www.motionpro.com/product/12-0060
Correct size though not the correct tubing, it will do for now.
Return to Tech
