A week with the grandsons and now back to the Bonnie.
The cylinder bore had quite a bit of taper in it so it will get a bore job and new .020 oversize pistons.
- 20180728_123037.jpg (123.34 KiB) Viewed 29133 times
The head gasket show a leak between cylinder bores. Double checking the head indicated it was warped.
I took about .005 off to clean it up, not enough to affect compression ratio or any other dimensions.
The back rim is straightened but will need new chrome. Best I can find is 2-3 months out. Hopefully by then
I can have everything else back together.
