Print your own timing wheels
Fri Nov 03, 2023 6:13 pm
by Vincent
I wanted to share a cool website that lets you print your own timing wheels including positions of intake open and close, exhaust open and close, and top of lobe. Then you just paste it on an old cd smeared with a thin coat of Elmer's glue and you're good to go.
https://www.blocklayer.com/degree-wheel
- IMG_4560.jpeg (150.26 KiB) Viewed 191465 times
Re: Print your own timing wheels
Fri Nov 03, 2023 6:15 pm
Hmm, maybe I will 3D print that in colour- then it could be whatever thickness wanted with centre hole size desired. Thanks
Fri Nov 03, 2023 6:21 pm
by Vincent
JH probably mills his out of 6061
Sat Nov 04, 2023 1:34 pm
Ha! I would not be surprised.
Sat Nov 04, 2023 9:05 pm
I used this program when degreeing the cams in the Triumph twin engine drag bike. Without a spec sheet for the cams which were stamped 'nitro' I was able to produce a degree wheel from the program.
- IMG_2640 copy.JPG (241.65 KiB) Viewed 191450 times
- IMG_2625 copy.jpg (175.41 KiB) Viewed 191450 times
