Did some research and also called a guy who has restored a few Triumphs. I was reminded that 62 was a transition year from the last pre-unit to unit construction. During this period some parts were being mixes to say the least, including cams.
Rather than pulling the head I set up some indicators to get the readings directly off the pushrods.
- 20181015_123502.jpg (245.25 KiB) Viewed 17729 times
This setup made it easy to degree the cams and determine the LSA or lobe center angle.
With this information I can now place the cam gears disregarding the punch marks.
I will now mark where the cams should be. Lesson learned.
- 20181015_121717.jpg (235.44 KiB) Viewed 17729 times
The painter called today saying the tank and fenders are finished. From the photos he sent, they look great.
- MVC-002F.JPG (124.75 KiB) Viewed 17729 times
