Yesterday I delivered the tank and fenders to Young Pon in Bellingham. He was referred to me by Bill Stevens, President of
Washington Vintage Motorcycles who has had several bikes painted by YP. His quality is top notch. He also has a small collection of vintage bikes from Bultacos, BMW, Nortons, Guzzis and more.
Meanwhile it's time to finish the primary side. The rotor had been loose on the crank and damaged the keyway in the crank.
The only option at this point was to make a special key that would take up the slack. The stator had a broken wire but was far enough from the stator it was an easy fix.
- 20180929_181657.jpg (213.04 KiB) Viewed 18435 times
The primary cover has been damaged before and welded on. There is still a small crack where the foot peg was bent back in to it so more welding is required.
- 20180929_104341.jpg (200.52 KiB) Viewed 18435 times
Next is finishing the primary cover. There were several nicks and scratches that need sanded out and then buffed. This will be the final piece to polish.
- 20180929_104328.jpg (178.15 KiB) Viewed 18435 times
Next will be adding the wheels.
