Battery suggestions
Battery suggestions
Postby ClineDesign » Sat Mar 23, 2013 2:41 pm
I'm looking for a small battery for my '77 GS 550 project. The battery must be small and able to be mounted flat. I've been looking at a Bikemaster 78-0542 12v TrueGel 7A Battery 4.48" (w) x 2.79" (d) x 4.17" because it will fit best. Can anyone point me to a better battery? Will this battery have enough cranking power?
Re: Battery suggestions
Postby Lotus54 » Sun Mar 24, 2013 9:07 am
I'd use a Shorai
Out local friendly dealer carris them.
1976 OSSA Super Pioneer- 78 Benelli 750 sei,72 250 2C Benelli, 68 Benelli Dynamo trail, 76 OSSA GPII Phantom, Beta XTrainer 300, Lotus Elan S3
Postby ClineDesign » Sun Mar 24, 2013 6:42 pm
Thanks for the tip. That battery will fit great. Do those batteries require a special charger thus increasing the cost? Will buy from our local friendly dealer for sure.
Postby Lotus54 » Sun Mar 24, 2013 8:14 pm
The website says you can use a regular charger- as long as it does NOT have a desulfation mode.
Battery Tender brand does not.
Some had said they had bad luck using other than the Shorai charger
Postby GUZZME » Tue Mar 26, 2013 10:42 am
IVE GOT THE BIKE MASTER GELL BATT. THEY WILL WORK UPSIDE DOWN AND TAKE ALOT OF SHOCK. NOT THE HIGHEST AMP OPTION BUT WOULD BE FINE FOR THAT BIKE. 60BUX. IVE GOT SHORAI BATTS AS WELL,USUALLY +100CCA OVER STOCK AND SUPER LITE WEIGHT. THEY CHARGE BEST WITH THE SHORAI CHARGER,FLAT RATE CHARGE. MOST BATTERY TENDERS WAVE OR PULSE. IVE GOT OTHER LI BATT OPTIONS AS WELL. SOME ARE SO STRONG THEY CAN CATCH A AIRPLANE ON FIRE!
GUZZME
Postby GUZZME » Tue Mar 26, 2013 4:36 pm
WEVE GOT A SHORAI LFX 14 L2(SAME CASE AS THE Z7S BIKE MASTER GEL). 14A/HR 210CCA,1.68LBS. THEY COME WITH A BUNCH OF STICKEY BACK FOAM PADS TO SHIM THE BATT BOX. $144.00 AND WESTERN POWER SPORTS HAS LI BATTS. THE SAME Z7S LI HAS 150CCA AND IS 1.3LBS $99.00.
GUZZME
Postby ClineDesign » Tue Mar 26, 2013 7:58 pm
I should be stopping in to purchase that Shorai within a week.
Postby salt-racer » Wed Mar 27, 2013 6:44 am
Hey Jay
Nice, clean electrical installation. This will insure trouble-free rides in the future....
Good Job!
Postby GUZZME » Wed Mar 27, 2013 10:24 am
WOW! NICE WORK. THATS GOING TO BE A FUN BIKE! TAKE A LOOK AT DIME CITY CYCLES,THEY MAKE SOME COOL LITTLE BITS.
GUZZME
Postby ClineDesign » Wed Mar 27, 2013 2:36 pm
I spend way too much time on Dime City... and soon they'll be offering cafe and street tracker parts for modern Triumph twins. No wonder I'm short of cash all the time.
