Print your own timing wheels
Postby Vincent » Fri Nov 03, 2023 6:13 pm
I wanted to share a cool website that lets you print your own timing wheels including positions of intake open and close, exhaust open and close, and top of lobe. Then you just paste it on an old cd smeared with a thin coat of Elmer's glue and you're good to go. https://www.blocklayer.com/degree-wheel
Vincent
Re: Print your own timing wheels
Postby Lotus54 » Fri Nov 03, 2023 6:15 pm
Hmm, maybe I will 3D print that in colour- then it could be whatever thickness wanted with centre hole size desired. Thanks
Postby Vincent » Fri Nov 03, 2023 6:21 pm
JH probably mills his out of 6061
Vincent
Postby Lotus54 » Sat Nov 04, 2023 1:34 pm
Ha! I would not be surprised.
Postby John H » Sat Nov 04, 2023 9:05 pm
I used this program when degreeing the cams in the Triumph twin engine drag bike. Without a spec sheet for the cams which were stamped 'nitro' I was able to produce a degree wheel from the program.
IMG_2640 copy.JPG (241.65 KiB) Viewed 170755 times
IMG_2625 copy.jpg (175.41 KiB) Viewed 170755 times
Return to Tech
