by Lotus54 » Sat Mar 11, 2023 5:47 pm
I wanted to do something better for an air filter. The original was a wire ‘brillo pad’ type setup and someone put some foam in instead. That didn’t really work.
So I found a K&N (I’m not a big fan of those, but should be ok for this bike) that would fit- IF I made up a spacer/adapter.
I should have made it out of aluminum sheet and bought a nut. But noooo. I bought some aluminum 4” ‘discs’ and cut it to work.
I have never done inside threads (just outside) so I did one first on a scrap. That worked fine- so figured I would just go ahead.
It took me quite some time- nothing happens in a hurry on this little mini-lathe. Metric thread cutting is different than SAE, just engage the half-nut, make a pass, then reverse it- then reverse again. This machine is setup so you can just change directions, not stop, change directions and go. So it was pretty easy.
The usual figuring how to hold it and cut what I wanted- and how to situate the tools…all took time (especially since I don’t know what I’m doing). But I got there in the end.
It works well and nobody but me will know what is in there. It was fun to make anyway.
- 5D77440B-66BC-4322-A565-8A09DB3AD58D.jpeg (54.23 KiB) Viewed 93916 times
- C2DB59DA-42E4-414A-B1AF-E3969468167D.jpeg (117.13 KiB) Viewed 93917 times
- CE8AE9F4-A40A-4E49-9226-1FFF8302CC2D.jpeg (45.85 KiB) Viewed 93917 times
- 678AF9A9-0776-40DB-A8E5-D914132311F5.jpeg (42.56 KiB) Viewed 93917 times
