With everything else going on, I did finally get some work done on the upper frame member. After 70 years of sludge buildup in the oil tank and no real good way of cleaning it out I decided to install a cleanout. I had tried the old nuts, bolts and gas to scour it clean but was still not satisfied. I was fortunate to find a shop that had a hot tank and that really did the trick.
- ufm cleanout1 Medium.jpeg (112.06 KiB) Viewed 68854 times
This will insure easy cleaning for the next 70 years.
- ufm cleanout3 Medium.jpeg (87.92 KiB) Viewed 68854 times
I finished it off using POR15 top coat.
- ufm cleanout4 .jpeg (291.82 KiB) Viewed 68854 times
I'm still in shock at the cost for cad plating all the exposed fasteners and hardware. Maybe I should have gone with stainless steel. Just wouldn't look original.
