So much for the LB rebuild, back to serious stuff
The crank is on the truing stand and the flywheels are parallel but both ends are out considerably. Very puzzling as the pin was squared with each flywheel before being pressed in. Going back over every move, I think I have found the problem. I used a different end piece on the hydraulic ram that wasn't deep enough to make contact with the shoulder on the ram.
When putting a feeler gauge between the end of the ram and the table I can now see the end of the ram is not true. The end piece was just following the end of the ram. The ram must be removed from the cylinder so the end can be trued in the lathe. I will probably make a new end piece that will be a perfect fit.
- IMG_5558.JPG (224.44 KiB) Viewed 16172 times
