I can see why someone may miss that little ball as the parts list doesn't show it. It points only to the other half of the clutch rod but when you read the text, is lists the 3/16" ball.
Call me next time you need a bit of aluminum as I have quite a lot of it. Just never know what you will find around here.
Well, another situation cropped up, the shift lever shaft wobbles so much it's hard to select a gear. Closer inspection showed that the bushing in the shifter shaft was worn badly due to a missing seal. This is a hardened bushing that is cast into the cover so not such a simple fix as it was to hard to drill oversize. After looking at the condition of this piece on the other motors it was apparently common to get mud/dirt in there causing the problem. I built a fixture so I could bore it oversize
and press in a bushing and then finish the bore to match the shifter shaft. A new seal 12x19x3 ?? is easily installed so now it shifts great. Tomorrow will be will be the first day for the boys to ride a real bike! Should be fun.
- Shift shaft bushing.JPG (198.47 KiB) Viewed 108857 times
