I've been sorting ignition parts as the project came with only one magneto. Finally scored one on Ebay which will need rebuilt. Next is making a 3 bolt adapter to fit the pre-unit engine case. Also need to modify a timing gear to fit the mag as well as clear the timing case. I will use the gear that came with the project as a copy to make the other one.
- IMG_3311 copy.JPG (253.72 KiB) Viewed 12297 times
The 'back' half of the gear must be turned down to clear everything and fit the taper shaft of the mag.
- IMG_3312 copy.JPG (212.49 KiB) Viewed 12297 times
The next step is to bore the gear and press fit the center part of a auto advance unit in place. This part has the tapered bore that fits the magneto shaft and also the internal left hand thread when used with the sleeve nut loosens the gear on the shaft for the purpose of timing.
- IMG_3319 copy.JPG (246.11 KiB) Viewed 12297 times
