So..
So..
Postby Dragonknee » Thu Sep 04, 2014 8:41 pm
What will be done to what bike this winter.... Mine are mostly getting suspension and such done to them. Waiting for the Guzzi to make its way over here...
Re: So..
Postby GUZZME » Sun Sep 07, 2014 8:21 pm
The guzzmondo needs to have the rest of the brake lines replaced,rear mast cyl rebuilt,calipers rebuilt and the carbs fettled. And new Pirelli sport demons. And the forks need a good go through. The KZB needs the forks done and could do with a shim under the springs. It could use a engine tear down just for new gaskets and to clean out the oil passages and decarbon the head.
GUZZME
Re: So..
Postby John H » Sun Sep 07, 2014 10:17 pm
I've ignored the 62 Bonneville long enough. Since I accidently 'dropped' it while taking it down from the mezzanine, I haven't been able to look at it. It took out the speedo and tach, dented the tank, rear fender and rear wheel. I have all parts required to finish it except a rear fender which hopefully George can help me sort out.
Other than that, back on English Thunder for more head work.
John
Re: So..
Postby DougErickson » Mon Sep 08, 2014 5:58 am
Bought a 73 Suzuki TC100 that will get a good work over, then onto the 350-4 and back to the rewire of the CL450. Also two 40 hp Evinrudes are up. If all that happens the MG may get some love too!
Re: So..
Postby Lotus54 » Tue Sep 09, 2014 2:41 pm
I should take delivery of my 1974 OSSA Explorer in two/three weeks.
I bought it from the original owner, looks pretty good overall.
So see what it needs, get it working and on the 'road' (it is plated) then decide to keep the old patina, or resto it.
Re: So..
Postby Dragonknee » Thu Sep 18, 2014 11:09 am
Good things to be doing... Looks to be a few bikes coming my way this winter... we will see
