Assembly of the links requires shims. Books have practically been written on the girdraulic forks, including how to rebuild them. I've found some ideas that are helpful while others are questionable. To do the job right requires special tooling which I have. Shimming the lower link requires the bushings be line bored as well as faced.
- IMG_5667.JPG (237.43 KiB) Viewed 27685 times
The eccentrics are designed for changing the rake and trail for side car use and also the attachment point for the spring boxes. This is where the shims are used and come in a range of .003" to .015". When the eccentrics are bolted to the steering stem the link must move free with a small clearance. Measuring and testing is awkward as the shims, spacers and cams go inside the link while the eccentric inserts in from the outside. I made two short sleeves to sub-assemble each side, then offer it up to the stem. This helps hold the shims and spacers in place.
Once in place the short sleeves are pushed into the stem to hold the pieces firm. If everything fits the spindle slides through, pushing the short sleeves out. Sorry it takes almost as much time explain as to complete.
- IMG_5670.JPG (290.5 KiB) Viewed 27685 times
