Yes, the expander is a pipe plug. The trick to doing this on an old lathe is to drill, thread and saw cut, then turn the diameter required for use without removing from the lathe.
I had to remove only a few thousandth to on all 3 surfaces to get things true again. The chain wheel rides on the the shoe carrier and the running end clearance is set at .006" so I had to keep that in mind when refinishing the surfaces.
- IMG_5358.JPG (234.16 KiB) Viewed 31262 times
The clutch shoes have new pivot bushings installed and spring pressure set. The 2 driving 'long' drive shoes require more spring pressure than the braking 'short' shoe. Lots of controversy as to just how much pressure the braking shoe should have. Much depends on the type of lining and all around wear.
- Plunger spring setting.JPG (242.69 KiB) Viewed 31262 times
When in neutral and the drum is turning, it is the centralizer pins against the post that keeps the shoes from dragging. The plunger in one shoe wasn't making contact so a special counterbore tool was used to deepen the counterbore by .040".
Boy! to think, I could have adapted a modern mulit-plate clutch in less than a day makes me wonder why I have spent so much time restoring this clutch.
- Plunger counter bore.JPG (170.83 KiB) Viewed 31262 times
