Got some time in on engine two today. Had the cylinder re-honed to straighten the bore on one hole that had a bit of a taper.
Even with diamond hones it took several minutes to get the job done. A lot different than honing cast iron for sure.
With tappets in place and cylinder bolted down the crank would get tight at one spot. Turns out one of the tappets, a new one, was sticking due to a large radius on the stem. Problem solved with a bit of grinding..
- IMG_4909.JPG (236.68 KiB) Viewed 57121 times
The 3 pc oil rings was tricky installing and then getting them to stay in the bore while adding the wrist pin. The bottom oil ring is only .030" above the pin. It's bolted down for the last time, I hope.
- IMG_4908.JPG (266.62 KiB) Viewed 57121 times
