by John H » Mon Feb 15, 2021 8:45 pm
More surprises today. When fitting the timing cover with the new driveshaft it became apparent the location of the needle bearing is off by .040". Don't now how it ever ran this way but it will be bored and sleeved then bored again to be centered on the end of the camshaft. Welding the bearing hub to the cover caused a lot of distortion so while in the mill a light cut was made to true up the mating surface.
- Attachments
- IMG_3739.JPG (266.31 KiB) Viewed 25892 times
