Benelli 250 Quattro
Re: Benelli 250 Quattro
Postby Lotus54 » Thu Jun 19, 2025 6:41 am
John H wrote:Did you solve the fouled plug issue?
I have been out of town and just got back. So I have not tested yet.
 I should have it all back together and ready to test today.
After some reading- I have heard of other bikes that were also rich with stock settings. The needle drop will certainly lean out a bit, just have to see if enough. Now that I’ve done it- it would not be too difficult to put in different needles or jets if required.
Postby Lotus54 » Thu Jun 19, 2025 3:55 pm
just gave it a test- still sooting up the plugs quite a bit.
I'm not sure why yet, float level was pretty close and original jetting.
But I just discovered the ones someone put in were a bit colder than original. So I'm getting some hotter plugs and perhaps that will solve most of it.
Postby John H » Fri Jun 20, 2025 7:21 am
Yeh, you probably recall the frustration I went through with the Z. Hotter plugs and pods helped a lot.
