Well it runs, but not that smooth. It won't idle and does the crackle and pop in both the intake and the exhaust. Set the air screws at 1-1/4 but no help. A leak down check was in range with intake and exhaust silent so the crankcase vent sound was clear. Compression was 90#, not unexpected. A short trip down the road and back and compression was 120# on all cylinders and should get better once tuning is finished and a few miles are clocked.
- Leak Down.JPG (200.23 KiB) Viewed 1021441 times
The spark plug check shows a lot of black suit so first thought is too rich, and second thought was an ignition problems. Another problem could be an air intake leak, none found.
The carbs were removed, disassembled and checked for any possible problem. None was found. Valve clearance was checked and is correct.
Now I'm down to ignition....I think. A quick check of spark plug caps revealed that two of them were between 4 and 5 ohms and two were nil. I'll leave it at that for now. A set of 4 caps are on order.
