TRIUMPH DESERT SLED RESTO
Re: TRIUMPH DESERT SLED RESTO
Postby Lotus54 » Thu Nov 21, 2024 7:49 am
So you heated the dent from the outside, then pushed an appropriate sized rod through to push out the dent?
I am just putting the Betor forks I sourced for the old Aermacchi back together. The Marzocchi ones just have too much pitting. These have a bit, but not very much and I put on my lathe and lightly cleaned up with some Scotchpads. They came with either Betor or Marzocchi.
I’ve only had one bike with a mageneto. The 62 Matchless 650 I bought in a basket (with no basket). I did get the bike running, but would not run long. Possibly the mag had some issues? Before I got to solving it I sold the whole bike to someone really mostly looking for a title. (I was 18, but I sure learned a lot about buying and fixing bikes in pieces)
Postby John H » Thu Nov 21, 2024 7:53 pm
Yes, I heat the dent then drive the insert to that spot. The cylinder hone finishes the job.
The wheel was another disaster. Still not sure what it's from but I don't think it's Triumph.
The brake baking plate is after market, I think.
The axle was modified to fit the Triumph forks. It was badly done so a new one was made up and now everything fits as it should.
When fitting the bearings I found a crack in the hub so add that to the surprise. Anyway it welded up nice so next will be straightening the fender and brackets and mounting the number plate.
Postby John H » Sun Nov 24, 2024 10:26 pm
This is the insert I used to remove the dent in the fork tube. A good coating of anti-seize kept it from getting stuck in the bore.
Fork dent.jpg (133.08 KiB) Viewed 2258 times
Postby John H » Wed Dec 04, 2024 10:11 pm
The forks are finally finished. The final step was straightening them. I got them within .003" and they slide nicely in the lower tubes.
Fork bent.JPG (201.75 KiB) Viewed 1741 times
The leather on this old Bates seat was in great condition but the foam was totally gone.
The base is 1/8" steel and in good condition so I glued up three layers of foam and shaped it to what I thought was close.
Looks like it's ready for another hundred mile desert race.
Next up will be using the english wheel to take some of the wrinkles out of the fenders.
Postby Lotus54 » Sat Dec 07, 2024 8:32 pm
The Triumph really shows what used to be common, everywhere you look more signs of someone out having fun. (And maybe a few crashes,which are never fun).
