Benelli 250 2C
Re: Benelli 250 2C
Postby Lotus54 » Wed May 01, 2024 5:26 pm
I’m working on another one of these for a buddy. I was going to start it before changing the Vape ignition/charging. But left cylinder has no spark. Then I found the flywheel nut loose and flywheel loose. So I think it was parked due to now spark on that side. I suspect the condenser (points tested ok).
So I will change install the Vape and go from there.
Re: Benelli 250 2C
Postby John H » Sun May 05, 2024 8:37 pm
Sounds like you are sold on Vape ignitions. I have one on the 370 Pursang but don't have instructions for setting it up. Hadn't thought about a loose flywheel.
Re: Benelli 250 2C
Postby Lotus54 » Tue May 07, 2024 9:18 pm
This is third one Ive done. Second 250- so it is going a lot easier.
Flywheel is located just by taper, but i hve had no issues. Just a bit moe ok to mke ure correct lotcation.
Will be ready for Z1 wiring soon.
Re: Benelli 250 2C
Postby Lotus54 » Thu May 09, 2024 6:44 am
New flywheel/stator mounted and timed
Re: Benelli 250 2C
Postby John H » Thu May 09, 2024 9:07 pm
Interesting that some other bikes attached these rotors without a key. The Z1R is the same and it causes real problems as the starter clutch bolts to the rotor.
