Postby Dragonknee » Thu Mar 26, 2020 9:56 am
John H wrote:Thanks Jim, wish more members would post projects here as well. Pretty easy once you learn to resize photos to 257 kb or less. There are apps available that make it easy too. You have some interesting projects I think members would like to see as well.
I think your talent and ability far out shines my oil changes and bolting things on .... Your the real deal and it shows
Postby John H » Fri Mar 27, 2020 10:54 am
A bit of bling will dress up the engine plates and hide a lot of blemishes. I did a bit of testing on the backside to get a pattern
going. The swirl is larger than I'd like but it's what I have so what do you think?
Postby Lotus54 » Fri Mar 27, 2020 11:10 am
I like it.
Postby ClineDesign » Fri Mar 27, 2020 3:53 pm
Looking great!
Postby ATinkerer » Fri Mar 27, 2020 4:12 pm
Definite progress being made.
Postby John H » Sun Mar 29, 2020 9:57 pm
Thanks guys. I want to see more of you guys share your projects. They're more interesting than you may think.
Larry says he will be showing some of his projects once he gets familiar with the website.
Postby Lotus54 » Mon Mar 30, 2020 7:29 am
I’m waiting on parts. Although I could start stripping the frame...
I also have another project, fitting a 4-shoe drum brake to the front of my 73 Benelli 250 SuperSport. It is off a Benelli 250 2C (2-stroke) and when I had one of those, the brakes were superb. Front now (two shoe, single) is pretty lame.
It will look quite original and make the bike more fun to ride.
Postby John H » Mon Mar 30, 2020 7:13 pm
The rear head has fins removed between the exhaust pipes to give the front engine throttle bodies for free air. The crankshafts are only 13-1/2" center to center. Not an ideal situation but Nitro doesn't rely on atmosphere like methanol or gas.
Further inspection shows a crack where the manifold is welded to the head. This could have happened when the engine blew. More surprises every day.
Postby John H » Tue Mar 31, 2020 10:46 pm
The story on the injectors is they were made for a Offenhauser midget race car which was about 100ci. The two Triumph engines equal about 100ci also.
IMG_2267 2.JPG (192.21 KiB) Viewed 47956 times
IMG_2236 copy.JPG (238.03 KiB) Viewed 47956 times
Next step will be disassembling the Hilborn 150 fuel pump. Hopefully it's rebuildable.
Postby ATinkerer » Wed Apr 01, 2020 8:18 am
Think it has been established that John can rebuild just about anything.
I have to believe the fuel pump will look much better when finished.
