SS100 V-Twin
SS100 V-Twin
Postby ClineDesign » Sat Jul 05, 2014 4:18 pm
Allen Millyard's Honda based SS100 V-Twin
http://youtu.be/j7m35Yts0AI
and on the road:
http://youtu.be/aTyUMgTWNv0
Re: SS100 V-Twin
Postby Lotus54 » Sat Jul 05, 2014 7:08 pm
That must have been a huge amount of work!
I've been following the guy that is making a V4 500cc to fit the Aprilaia RS250 chassis.
Re: SS100 V-Twin
Postby ClineDesign » Sat Jul 05, 2014 10:59 pm
Same guy made a 5 litre V-twin, better rubber mount that motor.
http://youtu.be/ND4EA0dnAM8
Published on Feb 4, 2013
This is the first test run of my 5 litre V Twin engine based on two Pratt & Whitney R1340 aircraft cylinders, all other parts are hand made including the crankshaft, con rods and crankcase wooden moulds, the crankcases were then cast in aluminium. The engine runs a dry sump with twin pumps, twin SU carbs, points ignition with manual advance / retard and twin plugs per head.
Re: SS100 V-Twin
Postby John H » Sun Jul 06, 2014 12:30 pm
Here's a hand built AJS V4 built by Dan Smith who is a member in our Vincent club. He also rode it from Vancouver BC
to Los Angeles and back.
http://www.theworldofmotorcycles.com/zo ... _1936.html
http://www.motorcycleclassics.com/class ... lideShow=4
